General Support
Android
> Firestick taking 30-45 seconds to open multi-source paths.
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
Flinger
2019-01-27, 18:24
I have thousands of movies and TV shows spread over 10 drives. Lately, it has started taking anywhere from 15 to 45 seconds to open my movies and or tv folder. Is this normal. Is there a ceiling that I should try to stay under?
fritsch
2019-01-27, 21:20
Nobody can tell you - without looking in your
Debug Log
- most likely an IP has changed in your network causing a timeout.
Stan464
2019-01-31, 14:45
Having the same issue as OP! i may of reduced the wait time by using NFS instead of SMB.
General Support
Android
