2019-02-02, 18:37
(2019-02-02, 09:20)maker3 Wrote: [ -> ]When UWP will return?what for? UWP version is targeting for xbox for now because it has a lot of limitation and have no benefits from usage it on PC
(2019-02-02, 18:37)afedchin Wrote: [ -> ]RE: no benefits from usage it on PC(2019-02-02, 09:20)maker3 Wrote: [ -> ]When UWP will return?what for? UWP version is targeting for xbox for now because it has a lot of limitation and have no benefits from usage it on PC
(2019-02-02, 23:25)YasharF Wrote: [ -> ]I am also fan of the UWP Version. Mainly because of the idea behind that and that there should be also support for the Win 10 S-Mode possible.(2019-02-02, 18:37)afedchin Wrote: [ -> ]RE: no benefits from usage it on PC(2019-02-02, 09:20)maker3 Wrote: [ -> ]When UWP will return?what for? UWP version is targeting for xbox for now because it has a lot of limitation and have no benefits from usage it on PC
Not entirely. As a user, I rather have a limited version that auto updates itself than a version that I have to manually track and install updates for. The ease of just leave it there and it will pull some kind of latest version is definitely something that I care for, especially since I have to maintain software on four desktops and two laptops. I know some other programs that check for updates when the user executes them, but even that model is a pain point itself since from the user's end we are executing an application so it would do something for us, not to get interrupted by maintenance prompts and options to do maintenance work.
(2019-02-02, 23:25)YasharF Wrote: [ -> ]Not entirely. As a user, I rather have a limited version that auto updates itself than a version that I have to manually track and install updates for.Please don't mix version. desktop version also can be distributed via the store with auto updates (currently desktop bridged version will install from the store on PC)
(2019-02-03, 10:24)MC Darkmaster Wrote: [ -> ]Mainly because of the idea behind that and that there should be also support for the Win 10 S-Mode possible.Nobody talks about Win10M we are mostly talking about desktop. Win10M has no future because MS announced no more developing it. I see no reason to support Win10M, we supported it in early UWP versions but currently Kodi requires os version which is not available on mobile devices (even on MS Lumia 950 XL)
(2019-02-03, 10:24)MC Darkmaster Wrote: [ -> ]The big goal should be to fix the limitations and then push again the UWP version to the Store.And how you are imagine this? How we can fix limitation of the UWP subsystem? Kodi UPW is limited not because we want this but because UWP subsystem has a lot of limitations. an UWP app doesn't even have access to the SMB network. we had to develop addon to return SMB support to Kodi.UWP
(2019-02-03, 13:01)afedchin Wrote: [ -> ]I have questions.(2019-02-02, 23:25)YasharF Wrote: [ -> ]Not entirely. As a user, I rather have a limited version that auto updates itself than a version that I have to manually track and install updates for.Please don't mix version. desktop version also can be distributed via the store with auto updates (currently desktop bridged version will install from the store on PC)
(2019-02-03, 21:31)afedchin Wrote: [ -> ]1. who knows?Does it use "C:\Users\[user]\AppData\Roaming\Kodi" to store its config data like the exe version does? Can I install the store version on top of the already installed exe version, or do I need to uninstall the exe version first?
2. no, it's exactly the same exe but installed via the store.
3. we have no plans to distribute uwp version to destop PC.
4. there are two versions in the store, destop bridge version for PCs and UWP for xbox.
(2019-02-03, 23:23)kbaudi Wrote: [ -> ]Does it use "C:\Users\[user]\AppData\Roaming\Kodi" to store its config data like the exe version does? Can I install the store version on top of the already installed exe version, or do I need to uninstall the exe version first?It uses this folder once on first start and makes shadow copy of it to another location. We can't control this, this "feature" of desktop bridge. You can install both, but can't launch both at the same time.
(2019-02-04, 10:34)vaLii Wrote: [ -> ]For some reason I am able to mount my SMB share but I dont have the SMB addon enabled as it isn't showing in my addon repository.
(2019-02-04, 10:46)afedchin Wrote: [ -> ]the addon is available for UWP version only.Got it. That explains why it's not showing up. After various other tests with adding/changing the way I'm importing my library I am now at an impasse in which heading to my movies crashes Kodi instantly. The same issue I get when updating/scanning my library.
(2019-02-03, 13:01)afedchin Wrote: [ -> ]Yes nobody (except you ) talks about Win10M. Win 10 S Mode has nothing to do with Win10M. It is meant as an additional security feature to only allow apps from the Microsoft Store and no .exe anymore.(2019-02-02, 23:25)YasharF Wrote: [ -> ](2019-02-03, 10:24)MC Darkmaster Wrote: [ -> ]Mainly because of the idea behind that and that there should be also support for the Win 10 S-Mode possible.Nobody talks about Win10M we are mostly talking about desktop. Win10M has no future because MS announced no more developing it. I see no reason to support Win10M, we supported it in early UWP versions but currently Kodi requires os version which is not available on mobile devices (even on MS Lumia 950 XL)
(2019-02-04, 16:50)MC Darkmaster Wrote: [ -> ]Yes nobody (except you ) talks about Win10M. Win 10 S Mode has nothing to do with Win10M. It is meant as an additional security feature to only allow apps from the Microsoft Store and no .exe anymore.why we should support crappy Win10S? if someone want to install Kodi then he/she should update his/her system. that's all.
