2019-01-30, 01:16
Library widgets , both movie and tv shows, instead of the video starting when I click on selected widget , is it possible to set it so that the info "page" shows , with the "play" button at the bottom , the page that you would see if you were to bring up the context men and select info whilst highlighting a widget ?
A bit like when you have live tv and pvr default action set to "show information" then you would select "switch" at the bottom of the screen?
Just think this would be a more user friendly way to see the info/plot then start a movie , rather than long pressing OK to bring up the context menu then pressing play ?
