Full Version: Dual Screens with Kodi v18
posted in another thread, but seems this one is the correct one.
got v18 UWP up and running all good, however cannot find the setting to set primary display as monitor 2 (dual monitor set up).
System\Display only has the fullscreen/Windowed option, no option above that to choose monitor etc.
when I manually move it, it's fine, until restart, upon which it defaults back to monitor 1.
how do I go about fixing this? in 17.6, had no problem with this.
(2019-01-30, 14:27)Phattchoo86 Wrote: [ -> ]got v18 UWP up and running all good, however cannot find the setting to set primary display as monitor 2 (dual monitor set up).
UWP version doesn't support multimonitor config. you can go to windowed mode (press \ ), move window to second monitor and go to fullscreen mode again (press \ ).
