I start to use tinyMediaManager in order to rename and manage my movie collection. Very interesting software, thank you !
I would like to know if it's possible to add an option to rename file with the 3D resolution type ? Half SBS/TAB or Full SBS/TAB ?
Thank you !
IIRC $3 in renamer should already contain those values, no?
Yes but it indicates only 3D SBS, not Half SBS
Perhaps it possible to match resolution and 3D tag.
If 3D tag and resolution 1920x1080 then 3D Half so H-SBS or H-TAB.
If 3D tag and resolution 3840x1080 or 1920x2160 then SBS or TAB.
How does MediaInfo detect this?
Can you fire it up (txt mode), and show me the value of the MultiView_Layout entries?
Cannot use resolution here, not all 3D movies are that big
Or we might have a chance to detect this via an uncommon aspect ratio then...
MediaInfo doesn't make a difference between Half and Full SBS, it shows :
MultiView_Count : 2
MultiView_Layout : Side by Side (left eye first)
And aspect radio is the same than 2D with a Half SBS/TAB because each eyes is reduced by 2 at horizontal or vertical
Real resolution for Half SBS or TAB is 1920x1080 ((2x960)x1080 or 1920x(2x540))
Real resolution for Full SBS or TAB is 3840x1080 or 1920x2160 ((2x1920)x1080 or 1920x(2x1080))
Others resolutions are wrong.
Thank you.
