2019-01-30, 15:20
Failed to resume HEVC stream
No problem playing from beginning
22:22:45.502 T:4781098432 DEBUG: ------ Window Init (Pointer.xml) ------
22:22:45.982 T:4781098432 DEBUG: ProcessMouse: trying mouse action leftclick
22:22:45.983 T:4781098432 INFO: Loading skin file: DialogContextMenu.xml, load type: KEEP_IN_MEMORY
22:22:45.985 T:4781098432 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
22:22:47.217 T:4781098432 DEBUG: ProcessMouse: trying mouse action leftclick
22:22:47.471 T:4781098432 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
22:22:47.484 T:4781098432 DEBUG: OnPlayMedia http://127.0.0.1/recorded/test.ts
22:22:47.489 T:123145518092288 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
22:22:47.489 T:123145518092288 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
22:22:47.737 T:4781098432 DEBUG: CCurlFile::GetMimeType - http://127.0.0.1/recorded/test.ts -> video/mp2t
22:22:47.742 T:4781098432 DEBUG: CPlayerCoreFactory::GetPlayers(http://127.0.0.1/recorded/test.ts)
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
22:22:47.742 T:4781098432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
22:22:47.742 T:4781098432 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
22:22:47.742 T:4781098432 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (VideoPlayer)
22:22:47.742 T:4781098432 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
22:22:47.742 T:4781098432 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
22:22:47.742 T:4781098432 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
22:22:47.743 T:4781098432 DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData
22:22:47.743 T:4781098432 NOTICE: VideoPlayer::OpenFile: http://127.0.0.1/recorded/test.ts
22:22:47.743 T:4781098432 DEBUG: OnPlayBackStarted: CApplication::OnPlayBackStarted
22:22:47.743 T:123145515945984 DEBUG: Thread VideoPlayer start, auto delete: false
22:22:47.743 T:123145516482560 DEBUG: Thread BackgroundLoader start, auto delete: false
22:22:47.743 T:123145515945984 NOTICE: Creating InputStream
22:22:47.744 T:123145515945984 DEBUG: CFileCache::Open - opening <recorded/test.ts> using cache
22:22:47.744 T:123145515945984 DEBUG: CurlFile::Open(0x7ff478cfbde0) http://127.0.0.1/recorded/test.ts
22:22:47.750 T:123145522462720 DEBUG: Loading settings for http://127.0.0.1/recorded/test.ts
22:22:47.752 T:4781098432 DEBUG: CVideoGUIInfo::InitCurrentItem(http://127.0.0.1/recorded/test.ts)
22:22:47.763 T:4781098432 DEBUG: CPlayerGUIInfo::InitCurrentItem(http://127.0.0.1/recorded/test.ts)
22:22:47.763 T:123145518092288 DEBUG: CAnnouncementManager - Announcement: OnChanged from xbmc
22:22:47.763 T:123145518092288 DEBUG: GOT ANNOUNCEMENT, type: 1024, from xbmc, message OnChanged
22:22:47.766 T:123145518092288 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
22:22:47.766 T:123145518092288 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
22:22:47.863 T:4781098432 DEBUG: ------ Window Init (DialogBusy.xml) ------
22:22:48.121 T:123145515945984 NOTICE: Creating Demuxer
22:22:48.121 T:123145519702016 DEBUG: Thread FileCache start, auto delete: false
22:22:48.121 T:123145515945984 DEBUG: Open - avformat_find_stream_info starting
22:22:48.498 T:123145519702016 INFO: easy_acquire - Created session to http://127.0.0.1
22:22:48.498 T:123145519702016 DEBUG: CurlFile::CReadState::Connect - Resume from position 465889420
22:22:48.680 T:123145516482560 DEBUG: Thread BackgroundLoader 123145516482560 terminating
22:22:49.354 T:123145519702016 INFO: CFileCache:rocess - Source read didn't return any data! Hit eof(?)
22:22:49.536 T:4781098432 DEBUG: ------ Window Deinit (Pointer.xml) ------
22:22:49.642 T:123145515945984 DEBUG: Open - av_find_stream_info finished
22:22:49.643 T:123145515945984 INFO: ffmpeg[70000CBBD000]: Input #0, mpegts, from 'http://127.0.0.1/recorded/test.ts':
22:22:49.643 T:123145515945984 INFO: ffmpeg[70000CBBD000]: Duration: 00:39:59.96, start: 1.400000, bitrate: 1553 kb/s
22:22:49.643 T:123145515945984 INFO: ffmpeg[70000CBBD000]: Program 1
22:22:49.643 T:123145515945984 INFO: ffmpeg[70000CBBD000]: Metadata:
22:22:49.643 T:123145515945984 INFO: ffmpeg[70000CBBD000]: service_name : Service01
22:22:49.643 T:123145515945984 INFO: ffmpeg[70000CBBD000]: service_provider: FFmpeg
22:22:49.643 T:123145515945984 INFO: ffmpeg[70000CBBD000]: Stream #0:0[0x100]: Video: hevc (Main) ([36][0][0][0] / 0x0024), yuv420p(tv), 1920x1080 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn, 29.97 tbc
22:22:49.643 T:123145515945984 INFO: ffmpeg[70000CBBD000]: Stream #0:1[0x101](kor): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 384 kb/s
22:22:49.643 T:123145515945984 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
22:22:49.643 T:123145515945984 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 1
22:22:49.643 T:123145515945984 DEBUG: CDVDInputStreamFile::SetReadRate - set cache throttle rate to 213649 bytes per second
22:22:49.643 T:123145515945984 NOTICE: Opening stream: 0 source: 256
22:22:49.643 T:123145515945984 WARNING: OpenStream - Unsupported stream 0. Stream disabled.
22:22:49.643 T:123145515945984 NOTICE: Opening stream: 1 source: 256
22:22:49.643 T:123145515945984 NOTICE: Finding audio codec for: 86019
22:22:49.643 T:123145515945984 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder ac3
22:22:49.643 T:123145515945984 NOTICE: Creating audio thread
22:22:49.644 T:123145516482560 DEBUG: Thread VideoPlayerAudio start, auto delete: false
22:22:49.644 T:123145516482560 NOTICE: running thread: CVideoPlayerAudio:rocess()
22:22:49.644 T:123145515945984 DEBUG: Prepare - Start position set to last stopped position: 603000
22:22:49.644 T:123145516482560 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_PAUSE: 0
22:22:49.761 T:123145519702016 DEBUG: CurlFile::CReadState::Connect - Resume from position 466008348
22:22:49.887 T:123145515945984 DEBUG: Seek - waiting for position 466138480.
22:22:50.012 T:123145519702016 INFO: CFileCache:rocess - Source read didn't return any data! Hit eof(?)
22:22:50.063 T:123145515945984 ERROR: ffmpeg[70000CBBD000]: [NULL] missing picture in access unit
22:22:50.063 T:123145519702016 DEBUG: CurlFile::CReadState::Connect - Resume from position 117120616
22:22:50.413 T:123145519702016 DEBUG: CurlFile::CReadState::Connect - Resume from position 117120240
22:22:50.544 T:123145515945984 DEBUG: SeekTime - seek ended up on time 602969
22:22:50.544 T:123145515945984 DEBUG: CVideoPlayer::FlushBuffers - flushing buffers
22:22:50.544 T:123145515945984 WARNING: CDVDMessageQueue(video):ut MSGQ_NOT_INITIALIZED
22:22:50.553 T:123145516482560 WARNING: Previous line repeats 1 times.
22:22:50.553 T:123145516482560 DEBUG: CDVDAudio:ause - pausing audio stream
22:22:51.547 T:123145516482560 DEBUG: CDVDMsgGeneralSynchronize - global timeout
22:22:51.547 T:123145516482560 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
22:22:51.547 T:123145515945984 DEBUG: CDVDMsgGeneralSynchronize - global timeout
22:22:51.547 T:123145515945984 DEBUG: CVideoPlayer::SetCaching - caching state 1
22:22:51.547 T:123145515945984 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
22:22:51.547 T:123145515945984 DEBUG: Prepare - starting demuxer from: 603000
22:22:51.547 T:123145515945984 DEBUG: CVideoPlayer::HandleMessages - player 1 reported state: 0
22:22:51.547 T:123145521926144 DEBUG: OnAVChange: CApplication::OnAVChange
22:22:51.554 T:123145518092288 DEBUG: CAnnouncementManager - Announcement: OnAVChange from xbmc
22:22:51.554 T:123145518092288 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnAVChange
22:22:51.557 T:123145516482560 DEBUG: CDVDAudio:ause - pausing audio stream
