*hold button on VIDEO_TS folder and select Play It plays the main menu but it freezes! You can't select any option! I tried 3 different DVDs on a MiBox
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Hi. Having the exact problem on my nvidia shield after updating to final v18.
Good to see I am not the only one. Will stick with rc 5.2 for now
Will upload logs later...
I also have the exact same problem with the nvidia shield and kodi 18 final
Greetings
(2019-01-31, 07:58)Amjak Wrote: [ -> ]Greetings
FYI... Greetings are not the same thing as providing a
debug log (wiki) with which we possibly can solve the DVD mystery.
And sometimes kodi completely crashes when I'm trying to play an DVD image
Sorry I don't know how to edit a post
Here is my log file resulting from the freeze when trying to play my dvd.iso files from my nas in nvidia shield tv.
https://paste.kodi.tv/ubuvozugek /
Thank you for your hard work
(2019-01-31, 08:01)Klojum Wrote: [ -> ] (2019-01-31, 07:58)Amjak Wrote: [ -> ]Greetings
FYI... Greetings are not the same thing as providing a debug log (wiki) with which we possibly can solve the DVD mystery.
Mistery?
No....
Simply remove the PR #15263 and everything works again.
Based on latest master (20199292):
https://wetransfer.com/downloads/1c197c4...152/a7b87c
Bye
Sorry for my ignorance but was is PR #15263 ?
(2019-02-02, 20:59)fritsch Wrote: [ -> ]This PR: https://github.com/xbmc/xbmc/pull/15263 are you sure? I rather suspect another one enabling mediacodec by default for DVD because some guys loudly screaming :-)
Try the apk from link above which has been built w/o the PR #15263. I mean this one:
Honestly I don't know why is causing the problem
I have just verified that the issue has been introduced starting from nightly build kodi-20190116-6733f379-master-armeabi-v7a.apk.
I checked the commits between this verision and the kodi-20190115-3b2bb11d-master-armeabi-v7a.apk (which is the last one working) and suspected that PR which is on Android.
Tried to build w/o and it work.
Bye
Oh! I know the problem! IsCurrentStream does not seem to work.
Can you post a
Debug Log please with the non working version?
(2019-02-02, 21:35)fritsch Wrote: [ -> ]Oh! I know the problem! IsCurrentStream does not seem to work.
Can you post a Debug Log please with the non working version?
All logs taken from a fresh install on latest nightly build kodi-20190202-bf6bc524-master-armeabi-v7a.apk with default settings.
https://paste.kodi.tv/atuxudoxil - Fire TV Stick (no 4K)
https://paste.kodi.tv/epubijukez - Zidoo X10
If you need can provide the log also on the Minix Neo U1.
bye
