I just updated to CoreELEC with Kodi Leia, and I installed Confluence. Previously, I had a number of views that show IMDB ratings, but now the only view with ratings is 'Fanart'. Is there a way to add the ratings in to the other views?
Most of the list views still show the ratings. Are you sure you haven't changed the sort by type?
I have it set to sort by date added. If I set the View to any of the below, it doesn't show the IMDB rating:
Media Info
Media Info 2
Media Info 3
List
Big List
Thumbnail
Poster Wrap
Also, none of these shows the MPAA rating either. Only Fanart shows the MPAA rating, and it's also the only one that shows the IMDB rating. Other than installing the confluence skin, and the Universal Movie Scraper, the system is pretty much stock.
However, if I change to sort by rating, OR Title, then I can see the rating in these views:
List
Big List
Fanart
Media Info
Media Info 2
What I really want is to be able to sort by date added, and see the rating. How can that be accomplished?
You'll need to get modding.
Thanks anyway, but I'm going to switch to a different skin.
Did you find a skin in the end?
