I just set up Kodi 18.0 from 17.6 and i can no more manage the items of the main menu with the native skin Estuary (for instance disable the new item Game). The screen Skin / Settings is no more present in the system settings menu.
Thanks for your answer
(2019-01-31, 12:50)jpjrando Wrote: [ -> ]The screen Skin / Settings is no more present in the system settings menu.
Go to
Settings / System / Interface / Configure skin / Main menu items
and enable/disable the items you want.
If you no longer have that menu screen at all, then your Kodi setup is somehow compromised.
Thanks a lot. It works fine
... but the location of this screen is not obvious
(2019-01-31, 13:12)jpjrando Wrote: [ -> ]... but the location of this screen is not obvious
It has been the same location from the start of Estuary.
Perhaps not everything is as obvious. "Ya cannot please everyone...".
