2019-02-01, 03:06
I downloaded the skin.minic version 6 from github and I am trying to figure out how to disable/remove the weather from showing next to the clock in the top right of the screen in kodi 18. Their should be a way to disable the weather in the following file: skin.lyrebird/1080i/includes.xml by removing something from the Navigation Bar section between lines 612 to 711 but I dont know what exactly. If I erase all the text from lines 612 to 711 then the whole header disappears including the weather but that is not ideal. What is the correct text to remove/hide the weather? I hope someone can find out and share with me. Thank you so much
