Full Version: REMOTEXBMC1.5 - update
RemoteXBMC News version Stable 1.5
ORIGINAL REMOTE CONTROLE XBOX for XBMC PC.
Remote control for xbmcpc : REMOTEXBMC 1.5 drivers include + news Keymap.xml.
For the original remote control xbox change USB + xbmc pc rev 13239 or 12882. version 1.5
- Connect your ir in USB
- install the drivers and restart
- insert the keymap.xml in the folder USERDATA and run the REMOTE XBMC 1.5
Update key option: HIDE XBMC = DISPLAY231 SHOWXBMC=DISPLAY231 SHUTDOWN and HIBERNATE next.
Please send me your comment.
thank all for your help.
function for the coffee soon Big Grin
works fine so far :-)
I tried installing your program, but it won't allow me to do it. I believe it is because my "system root" drive is H: and your default for the program is C:? Might you be able to fix this?
you can download is ok now
REMOTEXBMX News version Stable 1.5
**** NEWS VERSION UPDATE ****
Mousse control for Windows - Hide/Show/close xbmc - Shutdown/hibernate - Code control included in the readme.
DISPLAY 231 Hide- 131 Show- 252525 Close- 353535 Shutdown- 151515 Hibernate
Working 100% windows XP for the other version i dont no.
Thank for your comment.
