2019-02-04, 10:37
My TV box is Himedia Q5 Pro. The operating system is Android 7.x. My TV box came with Google Play Store.
My Kodi has been updated to version 18.
In Kodi version 17.x, Kodi detect my TV box's IR remote control as new controller, and I was prompted to configure it. I configured the arrow buttons as navigation, "Ok" button to select thing. In main menu screen, pressing the Ok button on my IR remote control will enter submenu. When playing video, pressing the "Ok" button will make kodi display the OSD. When kodi was displaying the OSD, I can then use the remote control to select subtitles, audio tracks, etc.
Then, the Kodi in my TV box had been automatically updated to Kodi version 18 without my knowledge. I am ok with this. After the update to version 18, Kodi again detect my IR remote control as new controller, and I was prompted to configure it. Again, I configured the arrow buttons for navigation, "Ok" button to select thing. In main menu screen, pressing the OK button will select thing and enter the submenu. When Kodi was playing video, pressing the "Ok" button will make the video pause instead of displaying the OSD.
I want to configure the actions of "Ok" button as follows:
1. When Kodi displaying the main menu, pressing the "Ok" button will enter submenu of the selected item.
2. When playing video, pressing the "Ok" button will make Kodi display the OSD.
3. When Kodi displaying the OSD, I can use the combination of arrow buttons + ok buttons to change the audio track, subtitles, etc.
In other words, make the "Ok" button behave like what happened when using Kodi version 17.x.
How to achieve this?
