Full Version: 10- Kodi 18.0 Enigma2 PVR error SSL
Buenas tardes.
Estoy intentando usar el Enigma2 con una coneccion https. Ya acregue mi certificado a /system/certs/cacert.pem. Pero el addon no inicia. el error es: ERROR: CCurlFile::FillBuffer - Failed: SSL peer certificate or SSH remote key was not OK(51).
No se que puede ser. Gracias por vuestra ayuda.
Un saludo.
PD: adjunto el log copleto:
14:35:17.716 T:10712  NOTICE: -----------------------------------------------------------------------
14:35:17.716 T:10712  NOTICE: Starting Kodi (18.0 Git:20190128-d81c34c465). Platform: Windows NT x86 64-bit
14:35:17.716 T:10712  NOTICE: Using Release Kodi x64 build
14:35:17.716 T:10712  NOTICE: Kodi compiled 2019-01-28 by MSVC 191627026 for Windows NT x86 64-bit version 10.0 (0x0A000006)
14:35:17.716 T:10712  NOTICE: Running on Windows 10, kernel: Windows NT x86 64-bit version 10.0.17134
14:35:17.716 T:10712  NOTICE: FFmpeg version/source: 4.0.3-Kodi
14:35:17.716 T:10712  NOTICE: Host CPU: Intel® Core™ i7-7700HQ CPU @ 2.80GHz, 8 cores available
14:35:17.717 T:10712  NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
14:35:17.717 T:10712  NOTICE: Running with restricted rights
14:35:17.717 T:10712  NOTICE: Aero is enabled
14:35:17.717 T:10712  NOTICE: special://xbmc/ is mapped to: C:\Program Files\Kodi
14:35:17.717 T:10712  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\Kodi
14:35:17.717 T:10712  NOTICE: special://xbmcbinaddons/ is mapped to: C:\Program Files\Kodi/addons
14:35:17.717 T:10712  NOTICE: special://masterprofile/ is mapped to: C:\Users\Rodriss\AppData\Roaming\Kodi\userdata
14:35:17.717 T:10712  NOTICE: special://home/ is mapped to: C:\Users\Rodriss\AppData\Roaming\Kodi\
14:35:17.717 T:10712  NOTICE: special://temp/ is mapped to: C:\Users\Rodriss\AppData\Roaming\Kodi\cache
14:35:17.717 T:10712  NOTICE: special://logpath/ is mapped to: C:\Users\Rodriss\AppData\Roaming\Kodi\
14:35:17.718 T:10712  NOTICE: The executable running is: C:\Program Files\Kodi\kodi.exe
14:35:17.730 T:10712  NOTICE: Local hostname: MSI_RSS
14:35:17.730 T:10712  NOTICE: Log File is located: C:\Users\Rodriss\AppData\Roaming\Kodi\kodi.log
14:35:17.730 T:10712  NOTICE: -----------------------------------------------------------------------
14:35:17.731 T:10712    INFO: loading settings
14:35:17.732 T:10712  NOTICE: special://profile/ is mapped to: special://masterprofile/
14:35:17.742 T:10712   DEBUG: CSkinSettings: no <skinsettings> tag found
14:35:17.744 T:10712  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
14:35:17.744 T:10712  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
14:35:17.744 T:10712  NOTICE: Default Video Player: VideoPlayer
14:35:17.744 T:10712  NOTICE: Default Audio Player: paplayer
14:35:17.744 T:10712  NOTICE: Disabled debug logging due to GUI setting. Level 0.
14:35:17.744 T:10712  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
14:35:17.755 T:10712  NOTICE: Running database version Addons27
14:35:17.774 T:10712  NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
14:35:17.774 T:10712  NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
14:35:17.774 T:10712  NOTICE: ADDON: game.controller.default v1.0.8 installed
14:35:17.774 T:10712  NOTICE: ADDON: game.controller.snes v1.0.8 installed
14:35:17.774 T:10712  NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
14:35:17.774 T:10712  NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
14:35:17.774 T:10712  NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
14:35:17.774 T:10712  NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
14:35:17.774 T:10712  NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
14:35:17.775 T:10712  NOTICE: ADDON: kodi.resource v1.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.album.universal v3.1.1 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.artists.universal v4.2.1 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.common.fanart.tv v3.6.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.1 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.local v1.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.themoviedb.org v5.1.4 installed
14:35:17.775 T:10712  NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: peripheral.joystick v1.4.6 installed
14:35:17.775 T:10712  NOTICE: ADDON: pvr.vuplus v3.16.2 installed
14:35:17.775 T:10712  NOTICE: ADDON: repository.xbmc.org v3.1.5 installed
14:35:17.775 T:10712  NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
14:35:17.775 T:10712  NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
14:35:17.775 T:10712  NOTICE: ADDON: resource.language.es_es v9.0.19 installed
14:35:17.775 T:10712  NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
14:35:17.775 T:10712  NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.53 installed
14:35:17.775 T:10712  NOTICE: ADDON: script.module.pil v1.1.7 installed
14:35:17.775 T:10712  NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
14:35:17.775 T:10712  NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
14:35:17.775 T:10712  NOTICE: ADDON: skin.estouchy v2.0.22 installed
14:35:17.775 T:10712  NOTICE: ADDON: skin.estuary v2.0.21 installed
14:35:17.775 T:10712  NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
14:35:17.775 T:10712  NOTICE: ADDON: xbmc.addon v18.0.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: xbmc.core v0.1.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: xbmc.gui v5.14.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: xbmc.json v10.1.1 installed
14:35:17.775 T:10712  NOTICE: ADDON: xbmc.metadata v2.1.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: xbmc.python v2.26.0 installed
14:35:17.775 T:10712  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
14:35:17.843 T:14860  NOTICE: Found 2 Lists of Devices
14:35:17.843 T:14860  NOTICE: Enumerated DIRECTSOUND devices:
14:35:17.843 T:14860  NOTICE:     Device 1
14:35:17.843 T:14860  NOTICE:         m_deviceName      : {85CCA8BE-EED5-4F28-A7D5-0BAA5710ECC4}
14:35:17.843 T:14860  NOTICE:         m_displayName     : Speakers - Altavoces (Realtek High Definition Audio)
14:35:17.843 T:14860  NOTICE:         m_displayNameExtra: DIRECTSOUND: Altavoces (Realtek High Definition Audio)
14:35:17.843 T:14860  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
14:35:17.843 T:14860  NOTICE:         m_channels        : FL, FR
14:35:17.843 T:14860  NOTICE:         m_sampleRates     : 48000
14:35:17.843 T:14860  NOTICE:         m_dataFormats     : AE_FMT_FLOAT
14:35:17.843 T:14860  NOTICE:         m_streamTypes     : No passthrough capabilities
14:35:17.843 T:14860  NOTICE:     Device 2
14:35:17.843 T:14860  NOTICE:         m_deviceName      : default
14:35:17.843 T:14860  NOTICE:         m_displayName     : default
14:35:17.844 T:14860  NOTICE:         m_channels        : FL, FR
14:35:17.844 T:14860  NOTICE:         m_sampleRates     : 48000
14:35:17.844 T:14860  NOTICE:         m_dataFormats     : AE_FMT_FLOAT
14:35:17.844 T:14860  NOTICE:         m_streamTypes     : No passthrough capabilities
14:35:17.844 T:14860  NOTICE: Enumerated WASAPI devices:
14:35:17.844 T:14860  NOTICE:     Device 1
14:35:17.844 T:14860  NOTICE:         m_deviceName      : {85CCA8BE-EED5-4F28-A7D5-0BAA5710ECC4}
14:35:17.844 T:14860  NOTICE:         m_displayName     : Speakers - Altavoces (Realtek High Definition Audio)
14:35:17.844 T:14860  NOTICE:         m_displayNameExtra: WASAPI: Altavoces (Realtek High Definition Audio)
14:35:17.844 T:14860  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
14:35:17.844 T:14860  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
14:35:17.844 T:14860  NOTICE:         m_dataFormats     : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
14:35:17.844 T:14860  NOTICE:     Device 2
14:35:17.844 T:14860  NOTICE:         m_deviceName      : default
14:35:17.844 T:14860  NOTICE:         m_displayName     : default
14:35:17.872 T:10712  NOTICE: Primary mode: [email protected] 60.00
14:35:17.873 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 640x480 @ 60.00Hz
14:35:17.873 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 640x480 @ 48.00Hz
14:35:17.874 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 720x480 @ 60.00Hz
14:35:17.874 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 720x480 @ 48.00Hz
14:35:17.874 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 800x600 @ 60.00Hz
14:35:17.875 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 800x600 @ 48.00Hz
14:35:17.875 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1024x768 @ 60.00Hz
14:35:17.875 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1024x768 @ 48.00Hz
14:35:17.875 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1152x864 @ 60.00Hz
14:35:17.876 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1152x864 @ 48.00Hz
14:35:17.876 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1280x720 @ 60.00Hz
14:35:17.876 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1280x720 @ 48.00Hz
14:35:17.876 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1280x800 @ 60.00Hz
14:35:17.876 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1280x800 @ 48.00Hz
14:35:17.877 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1280x960 @ 60.00Hz
14:35:17.877 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1280x960 @ 48.00Hz
14:35:17.877 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1280x1024 @ 60.00Hz
14:35:17.877 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1280x1024 @ 48.00Hz
14:35:17.878 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1366x768 @ 60.00Hz
14:35:17.878 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1366x768 @ 48.00Hz
14:35:17.878 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1600x1024 @ 60.00Hz
14:35:17.879 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1600x1024 @ 48.00Hz
14:35:17.879 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1680x1050 @ 60.00Hz
14:35:17.879 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1680x1050 @ 48.00Hz
14:35:17.879 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 2715x1527 @ 60.00Hz
14:35:17.880 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 2715x1527 @ 48.00Hz
14:35:17.880 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1920x1080 @ 60.00Hz
14:35:17.880 T:10712  NOTICE: Additional mode: Generic PnP Monitor #1: 1920x1080 @ 48.00Hz
14:35:17.880 T:10712  NOTICE: Checking resolution 16
14:35:18.197 T:13040  NOTICE: Running database version Addons27
14:35:18.198 T:13040  NOTICE: Running database version ViewModes6
14:35:18.198 T:13040  NOTICE: Running database version Textures13
14:35:18.199 T:13040  NOTICE: Running database version MyMusic72
14:35:18.201 T:13040  NOTICE: Running database version MyVideos116
14:35:18.202 T:13040  NOTICE: Running database version TV32
14:35:18.203 T:13040  NOTICE: Running database version Epg12
14:35:18.229 T:10712  NOTICE:   load skin from: C:\Program Files\Kodi\addons\skin.estuary (version: 2.0.21)
14:35:18.379 T:10712 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
14:35:18.394 T:10712  NOTICE: PERIPHERALS::CPeripheralBus::Register - new keyboard device registered on application->keyboard: Teclado (0000:0000)
14:35:18.394 T:10712  NOTICE: PERIPHERALS::CPeripheralBus::Register - new mouse device registered on application->mouse: Ratón (0000:0000)
14:35:18.396 T:10712  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:35:18.396 T:10712  NOTICE: Loaded playercorefactory configuration
14:35:18.397 T:10712  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:35:18.397 T:10712  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:35:18.402 T:10712  NOTICE: initialize done
14:35:18.402 T:10712  NOTICE: Running the application...
14:35:18.403 T:13640  NOTICE: ES: Starting UDP Event server on port 9777
14:35:18.403 T:13640  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
14:35:18.875 T:2204  NOTICE: AddOnLog: Enigma2 Client: pvr.vuplus - Enigma2::Open - VU+ Addon Configuration options
14:35:18.875 T:2204  NOTICE: AddOnLog: Enigma2 Client: pvr.vuplus - Enigma2::Open - Hostname: 'rss666.ddns.net'
14:35:18.875 T:2204  NOTICE: AddOnLog: Enigma2 Client: pvr.vuplus - Enigma2::Open - WebPort: '6663'
14:35:18.875 T:2204  NOTICE: AddOnLog: Enigma2 Client: pvr.vuplus - Enigma2::Open - StreamPort: '6666'
14:35:18.875 T:2204  NOTICE: AddOnLog: Enigma2 Client: pvr.vuplus - Enigma2::Open Use HTTPS: 'true'
14:35:19.112 T:2204   ERROR: CCurlFile::FillBuffer - Failed: SSL peer certificate or SSH remote key was not OK(51)
14:35:19.112 T:2204   ERROR: CCurlFile::Open failed with code 0 for https://mydeco.net:443/web/deviceinfo:
14:35:19.112 T:2204   ERROR: XFILE::CFileCache::Open - failed to open source <https://USERNAME:[email protected]:443/web/deviceinfo>
14:35:19.112 T:2204   ERROR: AddOnLog: Enigma2 Client: pvr.vuplus - enigma2::utilities::WebUtils::GetHttpXML - Could not open webAPI.
14:35:19.112 T:2204   ERROR: AddOnLog: Enigma2 Client: pvr.vuplus - enigma2::Admin::LoadDeviceInfo Unable to parse XML: Error document empty. at line 0
14:35:19.113 T:2204   ERROR: AddOnLog: Enigma2 Client: pvr.vuplus - Enigma2::Open It seem's that the webinterface cannot be reached. Make sure that you set the correct configuration options in the addon settings!
14:35:19.113 T:2204   ERROR: ADDON: Dll Enigma2 Client - Client returned bad status (1) from Create and is not usable
14:35:20.954 T:10712 WARNING: CGUIWindowManager - CGUIWindowManager::HandleAction - ignoring action 107, because topmost modal dialog closing animation is running
14:35:21.226 T:2204 WARNING: Previous line repeats 9 times.
14:35:21.226 T:2204   ERROR: PVR::CPVRClients::UpdateAddons: Failed to create add-on Enigma2 Client, status = 1
14:35:23.498 T:10712  NOTICE: stop player
14:35:23.498 T:10712  NOTICE: Storing total System Uptime
14:35:23.498 T:10712  NOTICE: Saving settings
14:35:23.504 T:10712  NOTICE: Saving skin settings
14:35:23.505 T:10712  NOTICE: stop all
14:35:23.506 T:10712  NOTICE: ES: Stopping event server
14:35:24.406 T:13640  NOTICE: ES: UDP Event server stopped
14:35:24.450 T:10712  NOTICE: stopped
14:35:24.650 T:10712  NOTICE: destroy
14:35:24.901 T:10712  NOTICE: unload skin
14:35:24.937 T:10712  NOTICE: unload sections
14:35:25.949 T:10712  NOTICE: application stopped...
Good afternoon.
I am trying to use the Enigma2 with an https connection. Already accrete my certificate to /system/certs/cacert.pem. But the addon does not start. the error is: ERROR: CCurlFile :: FillBuffer - Failed: SSL peer certificate or SSH remote key was not OK (51).
I do not know what it could be. Thanks for your help.
A greeting.
PD: attached the full log:
In Kodi 18 your SSL Cert needs to be in the Kodi Truststore (search the forums to find out how to do this) for self signed certs. Or alternatively you can get a proper cert from letsencrypt.
To be clear this is a feature of Kodi and not the addon.
