Full Version: Website install slower to load
I was using Kodi from the play store on my Nvidia Shiled TV but the skin I'm using isn't compatable with Leila so I had to uninstall Kodi and install from the apk from the Kodi website: kodi-17.6-Krypton-arm64-v8a.apk
Everything works but there is now a 4-5 second black screen between opening the app and the kodi splash screen showing. It's not necessarily a big issue but it does make me wonder whats happening. Has anyone else come across this before or found a fix? There wasn't any delay/black screen when it was installed from the play store.
Hi @jimmisavage,
In truth, only a debug log (wiki) posted to https://paste.kodi.tv will improve your chances of getting to the bottom of this.
Anything else would be guessing and not very helpful.
(2019-02-06, 16:27)OTinley Wrote: [ -> ]Hi @jimmisavage,
 Thanks OTinley, I should have some time this weekend so I'll be in touch then.
Thanks again
It turns out I had my refresh rate set too high Smile
It's working perfectly well now
