Full Version: Program Add-ons only.
Using this skin on Kodi Leia, the screen from the Add-ons button shows only my Program add-ons, and I can't figure out any way to access my other add-ons, except through the Settings menu.  I've gone over the settings several times and can find no way to change it, and no way to add the other add-on types in the submenu.  I can add individual add-ons, but not, say, a menu of my Video add-ons.
I thought maybe it got corrupted so I uninstalled, including all settings, and re-installed it, but same thing.
(2019-02-07, 07:03)Tarkus_ Wrote: [ -> ]Using this skin on Kodi Leia, the screen from the Add-ons button shows only my Program add-ons,
Yes, I have noticed this also when pressing Add-ons from the Main Menu. It should go to My Add-ons. Maybe an oversight.
I access via the Settings menu.
You can also add the Video Add-ons folder as a Favourite. Then in the Menu Settings, enable sub-menus for Add-ons, then link the Video Add-on Favourite entry to Favourite 1 at the bottom of the list.
(2019-02-07, 07:12)Karellen Wrote: [ -> ]You can also add the Video Add-ons folder as a Favourite. Then in the Menu Settings, enable sub-menus for Add-ons, then link the Video Add-on Favourite entry to Favourite 1 at the bottom of the list.
 Ah, that's a good idea.  Thanks (again).
