Full Version: Possible to extend splash screen time?
Hi
Great work on the UWP app. There have always been a 5 seconds delay when kodi has started up. Can that not be moved to the splash screen so that it will stay 5 seconds more so that
kodi is ready to respond when it has started?
Again thanks for a great product.
I believe you can set your own splash screen or splash video in Advancedsettings.xml. Make it a static image of your choice with a set duration if you know how long you want it to display I guess.
See https://forum.kodi.tv/showthread.php?tid=124124
(2019-02-07, 11:40)bo1e Wrote: [ -> ]I believe you can set your own splash screen or splash video in Advancedsettings.xml. Make it a static image of your choice with a set duration if you know how long you want it to display I guess.
Pretty sure that will not move the "thing" that kodi does when it has booted up to the actual loading area.
I'm not sure what that thing is though. On my xbox kodi is responsive instantly when the splash sequence is done and the main menu appears.
