Must we always say, that we will need a
Debug Log?
Your log has debugging disabled
and for the note. As long as your remote is not recognized as a keyboard (which I only know of if a Flirc dongle is in use or on some s905 devices), your keymap.xml file is wrong. Because if your remote is recognized as a IR remote (we will see that info from a
Debug Log), your xml file has to look like:
<keymap>
<global>
<remote> <- that's important, because currently you change keys for the "keyboard"
<power>shutdown</power
</remote>
</global>
</keymap>
Anyway, I also requested the info of the exact filename of that xml file and its location.
If you refuse to give the info I asked for, then I can't help.
Sorry im not familiar with debug /logs in Kodi
I have a remote(Rii i7 wireless airmouse) and keyboard(mini keyboard ) connected to the PC by a small dongle
i used keymap editor to reroute a back button. Strangly the standard back button is not working at kodi in all menus(at kodi 17 and 18) . so thats way this code" <key id="61573">back " and it is working for me
keymap generator makes the xml file . storred at ...//.kodi/userdata/keymaps
but i cannot reroute the power button i tried the code
<power>shutdown</power> , but the powerbutton has a different key id ( found out with keymap editor) <key id="61663">shutdown</key>
so the code works , for the back button on my remote
<keymap><global><keyboard><key id="61573">back</key></keyboard></global></keymap>
but not working for my powerbutton on my remote
<keymap><global><keyboard><key id="61663">shutdown</key></keyboard></global></keymap>
also when i changed <keyboard> into <remote>
So now i did go back to kodi 17, that is still working for me , but i hoped kodi 18 will be better and fixed some issues at kodi 17, but i found only more issues for me in kodi 18
