Full Version: Skin Helper Service Error with Estouchy v2.0.20
I'm getting a "Skin Helper Service Error" with Skin Helper v1.0.19 with Estouchy v2.0.20 on 18.0rc5.2-Leia under Ubuntu 16.04.5. I can post a full log if it helps, but the log just repeats the error below (about 80 lines worth) every time I enter a submenu, so there doesn't appear to be much there:
Quote:14:06:55.824 T:139675255682816   ERROR: GetDirectory - Error getting plugin://script.skin.helper.service/?action=alphabet&reload=0
14:06:56.164 T:139675138250496   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.AttributeError'>
                                            Error Contents: 'module' object has no attribute 'SSL_ST_INIT'
                                            AttributeError: 'module' object has no attribute 'SSL_ST_INIT'
14:06:56.189 T:139675775768320   ERROR: GetDirectory - Error getting plugin://script.skin.helper.service/?action=alphabet&reload=0
14:06:56.223 T:139675826124544   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
14:06:56.230 T:139676690147072   ERROR: GetDirectory - Error getting plugin://script.skin.helper.service/?action=alphabet&reload=0
14:06:58.195 T:139676941793024   ERROR: GetDirectory - Error getting /media/TV-Shows/ [removed-name]/extrafanart/]
posted on the Skin Helper development thread but didn't receive any responses.
Searching on Google, I found this similar issue reported. That poster resolved it by updating Skin Helper Service to the latest version on marcelveldt's github. Doing that only worsened my problem. Once I updated Skin Helper Service, I started getting TV Show - Next Aired errors as well as Skin Helper Service errors.
Any thoughts?
estouchy does not use the skin helper service at all.
either disabling or removing the addon would fix your issue.
Thanks. It did.
