Full Version: Problem Installing Addon Under Leah v18.0
I'm trying to install an addon I've written under Leah v18.0 and get the following error:
Quote:ERROR: CAddonInstallJob[service.ltvpl]: The dependency on xbmc.json version 0.0.0 could not be satisfied.
However, the addon.xml specifies:
[syntax= ]<import addon="xbmc.json" version="7.0.0 " />/syntax]
Why is the installer in Leah indicating the version is 0.0.0 and failing to install the addon?
There is no problem installing the addon under Krypton v17.6
