Hello, how are you? well before i format my pc the kodi 18 Leia worked perfectly, after formatting the pc i installed the kodi, i did everything correct, installed addons that worked before formatting the pc when i click to see a channel it simply fails out, and says that Kodi stop working, I have the drives updated
My question is
What programs or upgrades do I need to make it work? type java flash etc?
Windows 7 64Bit
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I did what you said, it gives sound but it does not give a video.
