Full Version: User rating
first time I'm using Transparency and I don't find how to put my user rating on a movie, music,...
Can someone help me ?
I'm on an Android box with Kodi V18 Leia
Thx in advance
Chrisbati
Highlight the movie to be rated
Call up the Information Page by pressing i on your keyboard or remote
Press Set my rating
thx for your answer, in the information page, I don't have "set my rating".
How can I do ?
Transparency as the skin provides that option whereas Eminence (the other skin you asked for in your other thread) doesn't have that option. For Eminence you could try to install the add-on I mentioned in the other thread.
For Transparency it works exactly like explained above.
