Full Version: What is the technical name for a multi row widget with vertical menu?
First, what do you call the type of widget such as in Titan Beta Krypton vertical menu, where you can scroll up-down, left-right within one widget?
Does anyone know of any of these for Leia? Estuary mod v2 has what I described, and I love the design but it's a bit buggy and wanted to try some others, if possible.
Screenshot might help.
(2019-02-09, 01:25)Hitcher Wrote: [ -> ]Screenshot might help.
 Like this:
https://www.google.com/search?q=titan+be...GfHWyJgNQM:
Don't know if there's an actual name for it but there's probably a few one of which is my fTV skin.
https://forum.kodi.tv/showthread.php?tid=207475
(2019-02-09, 10:34)Hitcher Wrote: [ -> ]Don't know if there's an actual name for it but there's probably a few one of which is my fTV skin.
 Thanks you
side menu is one name found in \Textures\icons\sidemenu
