Full Version: No CEC support on Intel Nuc after Update from 17.3 to 18 with Pulse CEC adapter
Hi all,
I have updated Kodi from 17.3 to 18. After the update process Kodi startet correctly and I wanted to control it with the remote control from my samsung tv.
On 17.3 everything was fine, but now nothing happpends. Kodi is also not able to control the Yamaha receiver wich is at the end of the hdmi cable.
I used a tablet to look after the list of available input devices but there is nothing about cec.
I looked after the problem on many websites and found no proper solution.
Here you can found the log starting Kodi:
https://paste.kodi.tv/ufulinariz.kodi
I use the CEC adapter from Pulse. I built the adapter into the Nuc and on all other versions of Kodi it worked excellent.
Does anyone have any idea what it might be?
Thank a lot.
Thread moved.
