Full Version: Whitelist mismatch against actual capabilities
Hello,
(Debug log at the end.)
Here is what is available on the Whitelist:
And here is what is available on my box straight in Android (I can actually switch to these resolutions):
How do I get all these resolutions on Kodi, so that I can switch both resolutions and framerates? Any switch to toggle or xml to edit?
Kodi debug log
copofutate.kodi (paste)
You need at least Android Nougat instead of Marshmallow to work better with Android's Display API and then the manufacturer has to implement it properly and include all the latest Amlogic patches in the firmware.
https://theminixforum.com/index.php?thre...-001fw.56/
I still don't think it will work properly.
(2019-02-13, 17:13)mo123 Wrote: [ -> ]You need at least Android Nougat instead of Marshmallow to work better with Android's Display API and then the manufacturer has to implement it properly and include all the latest Amlogic patches in the firmware.
 Thanks for the information. U9 Nougat firmware went back to beta status, for a good reason, and is working to even less extent that the Mashmallow one.
