2019-02-11, 22:15
Guys,
I have an issue where I could browse my workgroup network and see all the machines connected to that workgroup and now I can no longer see them. I had to add them in manually.
I'm not sure what changed. I am using the below setup
Nvidia Shield TV over WIFI
SMB is Open Media Vault, the latest version
I have 2 hard drives that I am sharing out
Like I said from the time I started using Kodi and using OMV I could browse these connections. I also tested this out on my phone with Kodi and I cannot browse them as well. All other apps
I have tested see them without issue (Nvidia Shield, Total Commander, ES file explorer) on my phone I have tested ASUS file manager and that can see the share. So I am not sure what changed.
It seemed like this changed after I was experimenting with having 2 routers act as access points sharing the same SSID. In the end I removed this because I didn't see any range gain but it was always
the same WIFI connection name. The phone is connected to the 2.4 radio and again that one cannot see it inside Kodi as well, or cannot browse it.
I feel like if I could just have a fresh button in Kodi when were it is browsing the share that it may pick it up but there is no refresh button. Nvidia Shield is fine on the network with Netflix and other services.
Using the manual connection I can access and stream my content. Kodi and update and install add ons. Kodi is set to default settings for SMB lowest client is none and highest is v3.
I've installed Kodi many times over the course of the original setup and each time I could browse. Now for some reason it stopped working.
Does anyone have an idea what happened?
thanks
thanks
