2019-02-12, 22:32
I'm experiencing "Skin Helper Service Widgets" (v1.0.38) errors and "TV Show - Next Aired" (v7.0.1) errors and haven't found much help resolving them. So, I decided to try and upgrade to 18.1 on the off chance it improves something.
I compiled 18.0rc5 after some minor library problems and didn't expect troubles with the next minor release. However, at the last step (kodi-x11) compilation is failing and I don't see an immediate problem. Is there anything that going from 18.0 to 18.1 that might complicate compiling? Any other thoughts?
Steps used:
The end result is:
Full logs are here: for git clean, for cmake configure, for compiling (verbosity turned off because results were way way too long for paste.tv), and onscreen output that wasn't written to the log.txt
Steps used:
Quote:sudo git clean -xfd && git reset --hard && git pull --rebase
git checkout tags/18.1rc1-Leia
cmake -DCMAKE_BUILD_TYPE=$Configuration -DENABLE_INTERNAL_FSTRCMP=1
cmake --build . > compile-log.txt
The end result is:
Quote:/home/kodi-user/xbmc/build/include/libavcodec/avcodec.h:5347:5: note: declared here
int avcodec_encode_audio2(AVCodecContext *avctx, AVPacket *avpkt,
build/video/video.a(VideoInfoScanner.cpp.o):VideoInfoScanner.cpp:function VIDEO::CVideoInfoScanner::GetFastHash(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&) const: error: undefined reference to 'KODI::UTILITY::CDigest::MdCtxDeleter::operator()(evp_md_ctx_st*)'
build/video/video.a(VideoInfoScanner.cpp.o):VideoInfoScanner.cpp:function VIDEO::CVideoInfoScanner::GetPathHash(CFileItemList const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&): error: undefined reference to 'KODI::UTILITY::CDigest::MdCtxDeleter::operator()(evp_md_ctx_st*)'
collect2: error: ld returned 1 exit status
make[2]: *** [kodi-x11] Error 1
make[1]: *** [CMakeFiles/kodi.dir/all] Error 2
make: *** [all] Error 2
