I'm a very happy user of the N2 but sometimes my Logitech Harmony Elite becomes unresponsive or is very slow. Connected via Ir.
Ik cannot tackle this problem and only occurs now and then.
(2019-11-24, 13:12)kanariepiet Wrote: [ -> ]I'm a very happy user of the N2 but sometimes my Logitech Harmony Elite becomes unresponsive or is very slow. Connected via Ir.
Same with my N2 and it doesn’t get better if I add my FLIRC. What I did was buy a cheap USB Bluetooth from Amazon and then use that with my Harmony Elite and no more issues.
(2019-11-24, 13:26)timstephens24 Wrote: [ -> ] (2019-11-24, 13:12)kanariepiet Wrote: [ -> ]I'm a very happy user of the N2 but sometimes my Logitech Harmony Elite becomes unresponsive or is very slow. Connected via Ir.
Ok, thanks for your clear answer, will order one.
How did you setup bluetooth in the Harmony software?
(2019-11-24, 13:33)kanariepiet Wrote: [ -> ]Ok, thanks for your clear answer, will order one.
I set it up as an Entertainment Device with the Manufacturer as Microsoft and the Device as Kodi.
(2019-11-24, 21:31)timstephens24 Wrote: [ -> ] (2019-11-24, 13:33)kanariepiet Wrote: [ -> ]Ok, thanks for your clear answer, will order one.
Have you gotten rid of the lag, mine can still lag at times hooked up over bluetooth.
wrxtasy
How N2 compares to Vero 4K+ in terms of GUI navigation performance?
Is it significantly/really noticeably snappier?
I am currently using a V4k+, but while I’ve got somewhat use to it, I am still missing the GUI speed I had with a cromebox before. Is N2 coming close to this or still far behind? Ah, and no fancy skin, just confluence...
The GUI feels the same as with a Chromebox, so it's very snappy. I use a Titan mod so it's a heavier one.
(2019-11-25, 01:14)lightsout Wrote: [ -> ]Have you gotten rid of the lag, mine can still lag at times hooked up over bluetooth.
Yeah no issues with lag after using Bluetooth. Just make sure all the commands are for the Bluetooth device and not the Odroid.
(2019-11-25, 01:34)olympia Wrote: [ -> ]@wrxtasy
I have both the Vero 4K+ and N2 (w/i eMMC). I also use the Titan MOD skin with Enhanced Home Screen w/i submenus & widgets + Netflix Views
The N2 is definitely snappier - startups quicker than Vero too. Its pretty much on par with my old and now defunct Wintel i5 PC.
I've really never had any problems connecting with windows, be it 10,7, 8 or any other OS. I always set a a new workgroup/domain name for all computers. Once I have that changed on everything on my lan, they all see each other and no problem connecting or browsing shares.
I have now set it up with bluetooth and can confirm its lightning gast but facing another problem:
I think I cannot power up and power down with bluetooth?
Shall it work correctly if I add Odroid (ir) for those functions as I don't want to leave the N2 always on?
I just leave mine on all the time. Power consumption is minimal.
(2019-11-26, 23:32)kanariepiet Wrote: [ -> ]I have now set it up with bluetooth and can confirm its lightning gast but facing another problem:
Yes. Just keep the IR device in your Harmony configuration (in addition to the Kodi one), and manually add its power toggle command to the "power on" and "power off" sequence of your "Watch Kodi" action via the Harmony software.
