2020-08-03, 08:57
Well hell, my N2plus arrived today. Glad someone else spotted the usbpower bug before I started it up!
Looking forward to the 4K tv arriving now. On back order.
(2020-07-30, 22:58)noggin Wrote: [ -> ]People need to be be particularly careful because HardKernel have a lousy warranty last time I checked (if you bought from them).
(2020-08-03, 22:05)hdmkv Wrote: [ -> ]Pretty poor after-sales support. Thankfully, my N2 from Ameridroid has been working perfectly since purchasing a year ago. But, have been considering an upgrade to N2+. Not sure if it's worth it just for CoreELEC use though, whether the performance improvements would be noticeable.
(2020-08-03, 05:36)wrxtasy Wrote: [ -> ]Is there a functional reason why someone would need 5V USB port on suspend or off?(2020-08-02, 17:04)madmax2 Wrote: [ -> ](2020-07-30, 22:58)noggin Wrote: [ -> ]People need to be be particularly careful because HardKernel have a lousy warranty last time I checked (if you bought from them). If you bought in Europe/UK from a European/UK retailer you may be better covered.what is the purpose of usbpower option in boot.ini ?
See HERE (click)
This is the Primary reason why developer boards are sent out to various parties to pick up such issues.
The usbpower option has been removed (click) from boot.ini anyway with the Release Candidate - CE v9.2.4 - so there is NO chance of N2+ users causing damage.
(2020-08-04, 06:24)madmax2 Wrote: [ -> ]If a device supports 'Wake on USB' then having power to the USB ports is required? That might be a reason.(2020-08-03, 05:36)wrxtasy Wrote: [ -> ]Is there a functional reason why someone would need 5V USB port on suspend or off?(2020-08-02, 17:04)madmax2 Wrote: [ -> ]what is the purpose of usbpower option in boot.ini ?
See HERE (click)
Is it to prevent some usb devices turning off?
You can use this setting to enable 5v power on the USB ports when entering suspend or power off,
# 0=off/1=on
# This setting will require a injected bl301 blob.
(2020-08-03, 22:05)hdmkv Wrote: [ -> ]Pretty poor after-sales support. Thankfully, my N2 from Ameridroid has been working perfectly since purchasing a year ago. But, have been considering an upgrade to N2+. Not sure if it's worth it just for CoreELEC use though, whether the performance improvements would be noticeable.Not sure if it's worth the money, as there is not much work for CPU in CE, and performance increase is not so huge.
(2020-08-06, 20:54)gurabli Wrote: [ -> ]My Odroid N2 2GB arrived today, already configured. The Panasonic 65gx800 tv should arrive tomorrow.Get an HDMI splitter, send one signal to the tv and one to the AVR.
I realized that my Denon X1000 avr doesn't do 4k and HDR/DV passtrough, which is a big shame, as I like this avr a lot. And I don't really use it a lot.
What do you think, how can I get at least DD/DD+ and DTS sound in 5.1? Maybe using the tv's optical out to AVR? Should I set the N2 to PCM 5.1 to decode DD and DTS and maybe the tv will pass this over to avr over optical?
(2020-08-06, 21:50)PANiCnz Wrote: [ -> ](2020-08-06, 20:54)gurabli Wrote: [ -> ]My Odroid N2 2GB arrived today, already configured. The Panasonic 65gx800 tv should arrive tomorrow.Get an HDMI splitter, send one signal to the tv and one to the AVR.
(2020-08-06, 20:54)gurabli Wrote: [ -> ]What do you think, how can I get at least DD/DD+ and DTS sound in 5.1? Maybe using the tv's optical out to AVR? Should I set the N2 to PCM 5.1 to decode DD and DTS and maybe the tv will pass this over to avr over optical?
(2020-08-06, 21:53)gurabli Wrote: [ -> ]I’m using one of these to do exactly what you want. Does DV and HDR+ perfectly fine.(2020-08-06, 21:50)PANiCnz Wrote: [ -> ](2020-08-06, 20:54)gurabli Wrote: [ -> ]My Odroid N2 2GB arrived today, already configured. The Panasonic 65gx800 tv should arrive tomorrow.Get an HDMI splitter, send one signal to the tv and one to the AVR.
It can be one option. Although, not easy to find a reasonable priced splitter that supports HDR+ and Dolby Vision.
I am fine with optical if that would work.
(2020-08-07, 03:21)PANiCnz Wrote: [ -> ](2020-08-06, 21:53)gurabli Wrote: [ -> ]I’m using one of these to do exactly what you want. Does DV and HDR+ perfectly fine.(2020-08-06, 21:50)PANiCnz Wrote: [ -> ]Get an HDMI splitter, send one signal to the tv and one to the AVR.
(2020-08-07, 07:03)gurabli Wrote: [ -> ](2020-08-07, 03:21)PANiCnz Wrote: [ -> ](2020-08-06, 21:53)gurabli Wrote: [ -> ]It can be one option. Although, not easy to find a reasonable priced splitter that supports HDR+ and Dolby Vision.I’m using one of these to do exactly what you want. Does DV and HDR+ perfectly fine.
This is really promising!
So I can have full everything for N2 to TV (like it was connected directly) and on Hdmi2 from splitter to AVR and enjoy DTS, TrueHD, DD+ etc. Sound really great.
Is HDMI-CEC (passtrough) also working?
And the harder part will be to get one in EU (although I see it is available on Amazon UK).
