2019-02-15, 20:54
Hi all,
I use a Shield v7.2.2 and Kodi leia v18 off. version.
I just wanted to delete my databases in Kodi and load the files once again. So i went to \\SHIELD\internal\Android\data\org.xbmc.kodi\files\.kodi\userdata\Database and deleted all *.db files. Kodi was not running when deleting the files. Then i turned off the Shield and on again. When i now start Kodi, it stops after 1 second and is closed automatically. I tried again but with the same result. In the folder \\SHIELD\internal\Android\data\org.xbmc.kodi\files\.kodi\userdata\Database i now have a folder CDDB and a file Addons27.db, nothing more.
When i take my backup and copy the old database folder, Kodi starts again. But as soon as i delete the db files, Kodi does not start again.
What can i do?
What can i do?
