Does anyone know of a way to apply transition animations to Slideshow.xml
I would like to achieve a slide transition animation similar to a fullscreen wraplist control when navigating left/right.
Anyone have any tricks/hacks/hints? It feels like MyPics section gets neglected a bit and I want to give it some love!
I use two same multiimage with different condition ( you can use more, four is similar like in slideshow)
From wraplist activate onup fake button to enable/disable condition "animtionimage"
xml:
<control type="multiimage" id="555">
<!-- Fanart -->
<width>1920</width>
<height>1080</height>
<fadetime>100</fadetime>
<animation effect="zoom" start="100" end="120" center="auto" time="10000" tween="cubic" easing="inout" pulse="true" reversible="true" condition="Skin.HasSetting(animtionimage)">Conditional</animation>
<animation effect="slide" start="15,15" end="-15,-15" time="5000" tween="cubic" easing="inout" pulse="true" reversible="true" condition="Skin.HasSetting(animtionimage)">Conditional</animation>
<aspectratio>keep</aspectratio>
<imagepath background="true">$INFO[ListItem.filenameandpath]</imagepath>
<visible>Control.HasFocus(79) + ![Container(79).OnNext | Container(79).OnPrevious]+![Container(79).Column(0)|Container(79).Column(2)|Container(79).Column(4)]</visible>
</control>
<control type="multiimage" id="556">
<!-- Fanart -->
<width>1920</width>
<animation effect="zoom" start="100" end="80" center="auto" time="10000" tween="cubic" easing="inout" pulse="true" reversible="true" condition="Skin.HasSetting(animtionimage)">Conditional</animation>
<animation effect="slide" start="-15,-15" end="15,15" time="5000" tween="cubic" easing="inout" pulse="true" reversible="true" condition="Skin.HasSetting(animtionimage)">Conditional</animation>
<visible>Control.HasFocus(79) + ![Container(79).OnNext | Container(79).OnPrevious]+[Container(79).Column(0)|Container(79).Column(2)|Container(79).Column(4)]</visible>
</control>
Angelinas - Is this in Slideshow.xml ?
What is control id="79" ?
How are you getting the path for the slideshow?
(2019-02-17, 04:31)jurialmunkey Wrote: [ -> ]@Angelinas - Is this in Slideshow.xml ?
No, that is "MyPics.xml" but this image is from "Slideshow.xml" and comand not working with arrow.Working only pageup pagedown and focus with mouse
This is some stupid limitation in Kodi
(2019-02-17, 04:31)jurialmunkey Wrote: [ -> ]What is control id="79" ?
79 is panel ID
(2019-02-17, 04:31)jurialmunkey Wrote: [ -> ]How are you getting the path for the slideshow?
Path in "Slideshow.xml" is from skinstring
(2019-02-17, 14:59)Angelinas Wrote: [ -> ]No, that is "MyPics.xml" but this image is from "Slideshow.xml" and comand not working with arrow.Working only pageup pagedown and focus with mouse
I thought so. Yeah the limitation in Slideshow.xml is what I'm trying to get around, but it doesn't look like it's possible. Thanks for the suggestions though!
