Full Version: Kodi Crash at launch- "Unable to Load Profile"
Guys,
I am not sure what happened but although I have been running Kodi 18.0 without any problem for months, it suddenly crashed and now I can't get it to run anymore...
I tried to figure it out myself updating Ubuntu with all latest packages (thinking it had to do with dependencies) and when I realized it was Kodi itself, going through all threads I could find on the topic.
But no success so far. So I need your help !!
Here is my Kodi crashlog:
 =10.5pt############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
 Date: 2019
 2 16 12:26:48
 Kodi Options:
 Arch: x86_64
 Kernel: Linux 4.15.0-45-generic #48-Ubuntu SMP Tue Jan 29 16:28:13 UTC 2019
 Release: Ubuntu 18.04.2 LTS (Bionic Beaver)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
12:26:45.957 T:140704408196032  NOTICE: -----------------------------------------------------------------------
12:26:45.957 T:140704408196032  NOTICE: Starting Kodi (18.0 Git:20190128-d81c34c). Platform: Linux x86 64-bit
12:26:45.958 T:140704408196032  NOTICE: Using Release Kodi x64 build
12:26:45.958 T:140704408196032  NOTICE: Kodi compiled 2019-01-28 by GCC 7.3.0 for Linux x86 64-bit version 4.15.18 (266002)
12:26:45.958 T:140704408196032  NOTICE: Running on Ubuntu 18.04.2 LTS, kernel: Linux x86 64-bit version 4.15.0-45-generic
12:26:45.958 T:140704408196032  NOTICE: FFmpeg version/source: 4.0.3-Kodi
12:26:45.958 T:140704408196032  NOTICE: Host CPU: Intel® Celeron® CPU G1840 @ 2.80GHz, 2 cores available
12:26:45.958 T:140704408196032  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
12:26:45.958 T:140704408196032  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi
12:26:45.958 T:140704408196032  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi/addons
12:26:45.958 T:140704408196032  NOTICE: special://masterprofile/ is mapped to: /home/fd/.kodi/userdata
12:26:45.958 T:140704408196032  NOTICE: special://envhome/ is mapped to: /home/fd
12:26:45.958 T:140704408196032  NOTICE: special://home/ is mapped to: /home/fd/.kodi
12:26:45.958 T:140704408196032  NOTICE: special://temp/ is mapped to: /home/fd/.kodi/temp
12:26:45.958 T:140704408196032  NOTICE: special://logpath/ is mapped to: /home/fd/.kodi/temp
12:26:45.958 T:140704408196032  NOTICE: The executable running is: /usr/lib/x86_64-linux-gnu/kodi/kodi-x11
12:26:45.958 T:140704408196032  NOTICE: Local hostname: fd-desktop
12:26:45.958 T:140704408196032  NOTICE: Log File is located: /home/fd/.kodi/temp/kodi.log
12:26:45.959 T:140704408196032  NOTICE: -----------------------------------------------------------------------
12:26:45.961 T:140704408196032    INFO: loading settings
12:26:45.961 T:140704408196032   ERROR: CProfileManager: error loading special://masterprofile/profiles.xml, Line 0
                                            Failed to open file
12:26:45.961 T:140704408196032  NOTICE: special://profile/ is mapped to: special://masterprofile/
12:26:45.961 T:140704408196032   FATAL: unable to load profile
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
When I opened guisettings.xml and profiles.xml in .kodi/userdata , both files are completely empty.
So again, I am really looking for your help me figure out how to recover.
If you tell me the step, I am pretty sure I can work it out although I am not a computer expert.
delete the empty files. If it still does not work, rename or delete the whole .kodi dir
Thank you so much wsnipex !
It worked right away as soon as I deleted the files.
I guess it was too simple to think about it ...
Rofl
