I am now having an issue with the following commands, using the released version of Leia (Kodi 18), on Windows. Latest version of Xonfluence 4.0.10 skin, but also tested in Estuary Skin.
These commands don't seems to pop up the screens I am trying to get:
The code I am using:
import xbmc
xbmc.executebuiltin('ActivateWindow(screencalibration)') - should popup the Screen calibration window. It did on Krypton with version 3.x.x of Xonfluence.
xbmc.executebuiltin("ActivateWindow(systemsettings)") - should popup the System settings window. It did on Krypton with version 3.x.x of Xonfluence.
Has something changed in the accepted format for Leia?
Any assistance would be greatly appreciated!
Cheers,
Ken
nope, nothing changed.
check your
Debug Log if any errors/warnings are logged.
Hmm, this is the error:
Activating window ID: 10011
2019-02-16 22:25:42.830 T:3011150624 INFO: Activate of window '10011' refused because there are active modal dialogs
2019-02-16 22:25:42.831 T:2978997104 INFO: CActiveAESink::OpenSink - initialize sink
2019-02-16 22:25:42.831 T:2978997104 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:@:CARD=AMLM8AUDIO,DEV=0
2019-02-16 22:25:42.831 T:2978997104 INFO: CAESinkALSA::Initialize - Attempting to open device "@:CARD=AMLM8AUDIO,DEV=0"
2019-02-16 22:25:42.836 T:2978997104 INFO: CAESinkALSA - Unable to open device "sysdefault:CARD=AMLM8AUDIO" for playback
2019-02-16 22:25:42.838 T:2978997104 INFO: CAESinkALSA - Unable to open device "default:CARD=AMLM8AUDIO" for playback
2019-02-16 22:25:42.839 T:2978997104 INFO: CAESinkALSA::Initialize - Opened device "front:CARD=AMLM8AUDIO,DEV=0"
2019-02-16 22:25:42.840 T:2978997104 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2019-02-16 22:25:42.841 T:2978997104 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2019-02-16 22:25:42.841 T:2978997104 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 4096, bufferSize 16384
2019-02-16 22:25:42.846 T:2978997104 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 4096, bufferSize 16384
2019-02-16 22:25:42.846 T:2978997104 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 372 ms
2019-02-16 22:25:42.846 T:2978997104 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
2019-02-16 22:25:42.846 T:2978997104 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR
2019-02-16 22:25:42.846 T:2978997104 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL, FR (ALSA: none)
2019-02-16 22:25:42.846 T:2978997104 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
2019-02-16 22:25:42.846 T:2978997104 DEBUG: Output Device : AML-M8AUDIO
2019-02-16 22:25:42.846 T:2978997104 DEBUG: Sample Rate : 44100
2019-02-16 22:25:42.847 T:2978997104 DEBUG: Sample Format : AE_FMT_S16NE
2019-02-16 22:25:42.847 T:2978997104 DEBUG: Channel Count : 2
2019-02-16 22:25:42.847 T:2978997104 DEBUG: Channel Layout: FL, FR
2019-02-16 22:25:42.847 T:2978997104 DEBUG: Frames : 4096
2019-02-16 22:25:42.847 T:2978997104 DEBUG: Frame Size : 4
2019-02-16 22:25:42.965 T:2478170992 INFO: Python interpreter stopped
2019-02-16 22:25:42.965 T:2478170992 DEBUG: Thread LanguageInvoker 2478170992 terminating
2019-02-16 22:25:42.971 T:2945426288 ERROR: GetDirectory - Error getting plugin://plugin.video.test/?action=setCalibrate
2019-02-16 22:25:42.971 T:2945426288 DEBUG: Thread waiting 2945426288 terminating
2019-02-16 22:25:42.977 T:3011150624 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
Any thoughts on what that means?
Cheers,
Ken
I actually found some info on a Google search. If I add this line before, it works:
xbmc.executebuiltin('Dialog.Close(busydialog)')
Probably just a poor workaround, but hey it works for now.
Cheers,
Ken
nah, that is the proper way.
any open dialogs must be closed before you can activate a new window.
Oh, OK thanks a million!
Cheers
Ken
