Full Version: No sound with Emulation Station/Retroarch
Subject says it all. LibreELEC 9.0 (Leia). It's a fresh install. All other sound is working (movies, tv shows, etc). If I launch a game from Emulation Station (or direct from Retroarch) I get no game sounds. If I navigate to my roms directory and launch a game from there with an emulator the sound works fine. I've played around with all the sound drivers in Retroarch and tried them all.... Appreciate any help you can give me. Thanks.
Possibly need to set your sound device manually by finding your audio device then adding it to the retroarch config file.
Make sure Retroarch is not running
1. SSH to Libreelec
2. Determine Audio device
3. Edit retroarch Config file
Then test
These two links should help
https://github.com/libretro/Lakka-LibreE...o-settings
http://www.lakka.tv/doc/Configuring-Lakk...-interface
Hey any one get this working I’m using LibreELEC on x86 9.0? And all sound through retroacrh still no luck how Do I stop retroarch
