Full Version: Adding menu item to (fuse)neue
Hey forum,
New member here. I’m BlueAlienBob. Pleased to meet everyone. Was hoping someone could help me out with a question.
I have added shows/movies to my library. There is no menu item ‘Library’.
Would someone be able to supply the necessary steps needed to add it as a new menu item?
It would be very much appreciated. Thank you in advance.
BlueAlienBob
88 views and not a single reply... can no one help me out here?
Just click on click on the + sign to create a new menu/submenu entry, select Choose item for menu, go to Common and select the library you want.
As a widget you can pick eg. Recent under Default widgets > Library Data Provider.
Thank you, I’ll give that a try.
@MorpheasGR
I did what you suggested and every time I go to select ‘Default widgets’ it says getting list and just hangs. The progress bar doesn’t move at all. I sat there and let it try for 10 minutes before hitting cancel and then that froze and I had to power down and restart. I attempted 2 more times with the same results. Any ideas?
