Extra Fanart
Extra Fanart was traditionally saved in the
extrafanart folder. Additional fanart images were saved to this folder for use as a slideshow by a compatible skin, usually by utilising the Skin Helper Service add-on or the Artist Slideshow add-on. The downside to this method is the skin needs to read the extra fanart directly from the extrafanart folder. This requires hard drives to wake causing delays in the GUI while waiting for the drives to become accessible. Filenames are not important as the skin slideshow simply displayed any image file in the folder.
v18 introduces caching of extra fanart, just like any other artwork in the library. This is the first step and must be considered
experimental. The advantages are quicker loading times and fewer wakings of hard disks. It is more difficult for skinners to implement this method.
Only a few skins are currently supporting this method, but more skins will implement this in the future.
There are three requirements to using this method...
1. Compatible Skin
Check with the skinner if this method is used by the skin.
2. advancedsettings.xml
The following tags are required in the
advancedsettings.xml file. These are the same tags as used in the Extended Artwork post above, but with the addition of the Extra Fanart.
<advancedsettings>
<musiclibrary>
<artistextraart>
<arttype>banner</arttype>
<arttype>clearart</arttype>
<arttype>clearlogo</arttype>
<arttype>landscape</arttype>
<arttype>fanart1</arttype>
<arttype>fanart2</arttype>
<arttype>fanart3</arttype>
<arttype>fanart4</arttype>
<arttype>fanart5</arttype>
<arttype>fanart6</arttype>
<arttype>fanart7</arttype>
<arttype>fanart8</arttype>
<arttype>fanart9</arttype>
<arttype>fanart10</arttype>
<arttype>fanart11</arttype>
<arttype>fanart12</arttype>
<arttype>fanart13</arttype>
<arttype>fanart14</arttype>
<arttype>fanart15</arttype>
<arttype>fanart16</arttype>
<arttype>fanart17</arttype>
<arttype>fanart18</arttype>
<arttype>fanart19</arttype>
<arttype>fanart20</arttype>
</artistextraart>
<albumextraart>
<arttype>back</arttype>
<arttype>discart</arttype>
<arttype>spine</arttype>
</albumextraart>
</musiclibrary>
</advancedsettings>
3. Saving Extra Fanart
The extra fanart must be saved alongside the other artwork with the following requirements:
1. fanartx is Extra Fanart. As many or as few can be added, but there must be a corresponding whitelist entry in the advancedsettings.xml file as shown above.
2. Do not zero pad the digits, ie use 1 not 01; use 12 not 012
3. The Music Library does not support the use of the Extrafanart folder, as used in the Video Library. It requires the Skin Helper Service add-on or the Artist Slideshow add-on to accomplish this.
4. The Universal Artist Scraper does not download extra fanart. The extra fanart must be manually sourced.
Example Artist folder in the Artist Information Folder with local artwork and nfo file.
