2019-02-22, 09:14
Hey,
After upgrading to kodi18.1 some string translation stopped working.
all my translation are in `/resources/language/resource.language.en_gb`
Most of translation work fine but some strings with id like:
30080, 30139, 30110 are overwriten with id: 30082
It looks like 30082 is FIRST ACTION LABEL, and all affected are ACTION LABELS too
I filled issue: https://github.com/xbmc/xbmc/issues/15578
edit: looks like it works in k17 but k18 is more restrictive about id's - or it was label based and now its id (cached?) based
changing id's from 'action' to 'action-number' solved the issue. thanks
xml:
<setting label="30082" type="action" id="action" action="RunPlugin(plugin://plugin.video.nakamori/?cmd=wizard)" option="close"/>
<setting label="30080" type="action" id="action" action="RunPlugin(plugin://plugin.video.nakamori/?mode=32)" option="close"/>
<setting label="30139" type="action" id="action" action="RunPlugin(plugin://plugin.video.nakamori/?mode=33)" option="close"/>
<setting label="30110" type="action" id="action" action="RunPlugin(plugin://plugin.video.nakamori/?mode=31)" enable="System.HasAddon(script.module.nakamori)" option="close"/>
