Full Version: passthrough not working
Hello, audio passthrough no longer works for me in the newest version of KODI. When i enable it i get no audio and the picture will freeze after a few secs. I am running windows 10 with a soundblaster Z soundcard and have 5.1 logitech audio system using optical. DTS digital is enabled in creative software.
Passthrough doesn't work for me unless I set my audio device to use WASAPI in Kodi, did you already do this?
If it used to work for you in v17, then you're experiencing this issue: https://github.com/xbmc/xbmc/issues/15490
Try toggling passthrough off and then back on again.
