2019-02-25, 13:56
install SimplePlaylists plug in
add this to AppData\Roaming\Kodi\userdata\keymaps
make playlists by pressing F2 only 1 item needs to be added to create playlists i used movie widget and tv widget
goto addons left click on SimplePlaylists and add your playlists to favourites
open\AppData\Roaming\Kodi\userdata\favourites.xml
find <control type="group" id="5000">video
find </include> now add thit
<param name="widget_header" value="movie widget"/> is your name for the play list
<param name="list_id" value="5195"/> look at where you place it and change the number so it is higher then the one above and lower then the one beneath
for tv shows <control type="group" id="6000">
xml:<keymap>
<global>
<keyboard>
<f2>RunPlugin(plugin://script.simpleplaylists/?mode=addCurrentUrl)</f2>
<f4>Skin.ToggleSetting(HomeMenuNocustom3Button)</f4>
<F5>XBMC.ReloadSkin()</F5>
<F7>Notification(Testing 123,Hello world)</F7>
<F8>Skin.ToggleDebug()</F8>
</keyboard>
</global>
</keymap>
now open home.xmlxml:
<favourites>
<favourite name="Video: movie widget">ActivateWindow(10025,"plugin://script.simpleplaylists/?mode=showPlaylist&url=Video%3a%20movie%20widget",return)</favourite>
<favourite name="Video: tv widget">ActivateWindow(10025,"plugin://script.simpleplaylists/?mode=showPlaylist&url=Video%3a%20tv%20widget",return)</favourite>
</favourites>
you need to copy plugin://script.simpleplaylists/?mode=showPlaylist&url=Video%3a%20movie%20widget this will be your playlist name
change plugin://script.simpleplaylists/?mode=showPlaylist&url=Video%3a%20movie%20widget with your favourites linkxml:
<include content="WidgetListPoster" condition="Library.HasContent(movies) ">
<param name="content_path" value="plugin://script.simpleplaylists/?mode=showPlaylist&url=Video%3a%20movie%20widget"/>
<param name="widget_target" value="videos"/>
</include>
xml:
<include content="WidgetListPoster" >
<param name="content_path" value="plugin://script.simpleplaylists/?mode=showPlaylist&url=Video%3a%20tv%20widget"/>
<param name="sortby" value="tv widget"/>
<param name="sortorder" value="descending"/>
<param name="widget_header" value="tv widget"/>
<param name="list_id" value="6150"/>
</include>
