Hello, I am French so excuse me from my English aproximatif. Since yesterday I have a problem to access add-ons that allows me to watch TV. Indeed, it puts me an error message as soon as I try to open it ...
The message is: "Check The Log For More Information". What should I do to fix this problem that happens quite often?
Thank you for your answers.
Cordially.
(2019-02-28, 10:52)PeterPedro Wrote: [ -> ]What should I do to fix this problem that happens quite often
Provide the log so we can see what the problem is
Im getting the same problem but I dont know how to checkĀ
the log or error.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
