2019-02-28, 16:02
As per title. V 18.1 on Android TV (Sony Bravia)
Leanback recommendations are great... except that they don't respect the profile setup and will allow any user to watch content behind a passcode protected profile.
I have a set-up as follows:
Even if it is pulling from the "Master" profile - that should still need a sign in before playing as that profile is protected...
Only workaround is to disable recommendations from Kodi - which is a shame
- Kodi boots into "default", open profile with access only to sources containing family-friendly movies etc
- By signing out from default you can switch to a separate "PG" profile which has access to separate sources content that "probably requires and adult in the room before watching" (e.g. 15, 18 rated movies etc.)
- The Master Profile (also password protected) has access to all, but isn't used - apart from to manage the others
