2019-04-06, 17:57
The best way to workaround broken firmware is patching the native player instead of fixing the root cause ... that logic makes no sense.
(2019-04-06, 17:10)Stile35 Wrote: [ -> ](2019-04-06, 15:40)Jerem Wrote: [ -> ]Got the same problem on a 55PUS7503 even with the new firmware .230. However, if I watch a movie with Philips native app it works fine.So, with .230 in Kodi it is wrong aspect ratio but with native player it is fixed?
I am not sure was it correct on Philips native player also on previous .222 FW.
Now it seems like Kodi should fix something because I doubt that Philips will release new FW if native player is working correctly.
(2019-09-08, 18:48)mmace Wrote: [ -> ]Is there any resolution to this a few months on?No solution till today. Philips didn't fix it in the newest firmware TPM171E_107.1.38.0. I am not hoping it will be ever fixed...
I just took delivery of my new Philips 49PUS7803/12, which I got to run Kodi at a good price (as it's last year's model) but videos are stretched.
I'm on the latest firmware and on the latest Kodi.
This post is from earlier this year so I'm hoping there's a solution now.
Plex works fine, but I prefer Kodi.
(2019-09-28, 21:51)R2d3 Wrote: [ -> ]What is the best workaroundThe workaround that works best for you.
(2019-09-28, 22:15)Klojum Wrote: [ -> ](2019-09-28, 21:51)R2d3 Wrote: [ -> ]What is the best workaroundThe workaround that works best for you.
And then save that setting for all videos.
(2019-10-05, 21:27)iHomer Wrote: [ -> ]Another one here with the same problem on a 58PUS7304, it's so annoying. I tried uninstalling Kodi and installing it again. I don't know if it has something to do with Kodi or with the TV itself. It'd be great for the Kodi devs to have a look at it2019 model. Try to return it and get a Sony TV instead if you want an Android TV.
(2019-10-05, 23:16)Tobby Wrote: [ -> ]I like my tv ;-) so no thanks.(2019-10-05, 21:27)iHomer Wrote: [ -> ]Another one here with the same problem on a 58PUS7304, it's so annoying. I tried uninstalling Kodi and installing it again. I don't know if it has something to do with Kodi or with the TV itself. It'd be great for the Kodi devs to have a look at it2019 model. Try to return it and get a Sony TV instead if you want an Android TV.
(2019-10-05, 23:16)Tobby Wrote: [ -> ]2019 model. Try to return it and get a Sony TV instead if you want an Android TV.not really a solution is it? Philips is cheaper and has ambilight, plus returning it will not make Philips do anything, they won't even know the reason people return their TVs to the stores.
