2019-03-02, 13:47
2019-03-02, 13:47
2019-03-02, 19:01
if you just add one movie, the cache should be built automatically - there is no need to rebuild the whole cache!
as the action indicates - it rebuilds everything! processing/scaling several thousands of images depending on the size of your library
2019-03-02, 19:25
just tested this in v3 - if the image cache has been built up once, update data sources is fast since there is nothing to do...
2019-03-02, 21:05
Quote:if you just add one movie, the cache should be built automatically - there is no need to rebuild the whole cache!Sorry, I am not quite sure to understand, I do not initiate a rebuild, TMM does it automatically after movies have been added and / or scraped or am I missing anything?
Quote: as the action indicates - it rebuilds everything! processing/scaling several thousands of images depending on the size of your libraryYes, obviously, so how could I make TMM to not to do this?
Quote: just tested this in v3 - if the image cache has been built up once, update data sources is fast since there is nothing to do...Sorry, I do not have TMM 3 but 2xx, the latest stable one, so what does that help for my version? Or is there a stable 3?
