2019-03-03, 05:08
I have 3 systems all on Windows 10 and updated to latest build; All point to the same data sources (pasted same config files to all systems).
Only 1 of my systems will play the ISO file's menu while the other 2 throws an error stating "The menu of this bluray is not supported". If I try to run the menu again a second time Kodi crashes to desktop with no error codes. If I tell Kodi to play the main title (top option) it seems to work fine on the 2 troubled systems.
Anyone have any idea why 1 system will play the menu properly, while the other 2 systems will not?
I posted my log to paste.kodi.tv and saved it, but I am not sure what I am supposed to do from there.
