Full Version: Kore not working after Kodi update to Leia
After update to Leia on Odroid C2 (Libreelec), Kore app is not finding the Kodi anymore.
Settings are all as it should be:
Enable remote control over HTTP - enabled
Gate - 8080 (tried 80, 9090, 8081)
name - set to default (kodi)
password - default (not set)
Allow RC from app on this system - enabled
Allow RC from app on other system - enabled
UPnP support - Enabled
Im on same network but Kore will not see Kodi!
Is there something else I should try?
Check for a message box in the right upper corner that the "Remote communications server" fails to start during the booting of Kodi.
If it's not there, that part should be okay.
