2008-06-19, 06:34
I have a USB-UIRT device and a remote with the XBOX IR command set (work perfectly on my original XBOX)
I have followed instructions from ezhtpc blog to install LIRC. But XBMC does not respond... the USB-UIRT receive light blinks so I know it is getting commands.
lircmap.xml & keymap.xml are in /user/.xbmc/userdata folder.
Is there anything I need to tweak/change/update?
thx!
thx!
