Full Version: Kayo Sports (Australia)
Pages: 1 2 3 4 5 6 7 8 9 10
@matthuisman I've removed your URL to a commercial VPN provider. There is a Kodi VPN policy (wiki) these days.
@Klojum
Oh, sorry!
Wasn't aware of that Smile
This app is giving errors and isn’t being supported by @matthuisman . Is there anyone working on this now?
(2020-02-24, 03:16)matthuisman Wrote: [ -> ]@HomerJau
https://www.matthuisman.nz/2020/02/bad-n...-news.html
Thanks so much Matt. Thanks for the link AND Thanks for all your great Kodi related work!
Good luck and all the best for the future!
(2020-03-01, 07:19)RoadKill69 Wrote: [ -> ]
I have add you Addon and I can see the Kayo app but when I try and logon it give me an unexpected error. I am using a vpn and it’s set to Australia but it still won’t let me access the Kayo sports options.
Any help on this would be appreciated
Rob
This is the error I get
Value error: no JSON object could be decoded
They are blocking most vpns now.
Vpn talk isn't allowed on this forum, but that's why its not working
(2020-09-05, 04:55)Geegee Wrote: [ -> ]I am using a vpn and it’s set to Australia
To Whom It May Concern... We have a VPN policy (wiki) on this forum. Please read what it's all about.
Does anyone know if this add on is still working?
it installs fine however throws a JSONDecodeError error whenever I try to play anything.
(2020-09-11, 15:59)Paggnr Wrote: [ -> ]Does anyone know if this add on is still working?
thats because you trying to access outside of Australia
Hi, not really sure to ask for support help.  A couple of days ago I stumbled upon the Kayo Addon - thank you to Matt, it is awesome!  Way better than navigating the native apps and casting. I installed on a few different Kodi clients on ver 18.8 mix of Windows and Libreelec Pi and x64 and all went fine and was working a treat for VOD and Live with Guide data.
Last night I tried installing on another Libreelec Pi3 and the install went fine until the IPTV Merge. That process failed and no guide data or channels are added, whereas it worked on the installs done a couple of days prior. I then browsed to the Addon menu and went to Live Channels and was presented with the same error.
I then tried the same on my previous installs (different machines) and they are all doing the same now.  On the previous installations that work I can still browse to the guide and launch a channel on the previous installs though. The error I am seeing is paste below.
I've tried force updating the Addon.
Any clues?
Thanks CV8R
@CV8R
thanks for letting me know.
Kayo changed the panel id for live channels.
Just pushed 0.9.8 that should fix it up.
Force update to get now.
Please let me know if all instances still work.
