Full Version: Control Kodi with These Siri Shortcuts
I've recently made a few Siri Shortcuts in order to have voice control over Siri. These shortcuts leverage texturecache.py utility and SSH. I placed texturecache.py in my PATH to make things easier. You'll also have to enter your own ssh details.
Here's what I have so far:
pause
resume
stop
set volume (as number)
mute
unmute
scan video library
And my favorite:
play movie title
Theres also this shortcut that allows you to create a "folder" for shortcuts so you can have easy access to them in widgets, for example.
Hello, can you explain how I can use it with a Kodi installed on raspberry pi 3?
(2020-01-13, 22:45)konrul Wrote: [ -> ]Hello, can you explain how I can use it with a Kodi installed on raspberry pi 3?
You need to install texturecacheutility on your pi. You can find it here on the Addon forums and instructions on setting it up. For ease of use place the .py file in your PATH. Or, you can edit the shortcut to call the full path. You also need to have SSH enabled on your pi. You'll have to edit the shortcut to reflect your SSH credentials. Thats pretty much it.
