2008-06-19, 18:59
2008-06-19, 19:31
Do you mean normal posts or what? if you do:
dude.. 'tuxbox'...
it doesn't work currently because it broke down.. there is a patch but it's not being allowed because its to 'vague'
you can apply the patch to the source of xbmc linux for yourself and use it..
crocodille is also working on the EPG(dreambox) for xbmc i believe...
else what is dreambox text. subtitles?
dude.. 'tuxbox'...
2008-06-19, 19:55
@karra, please respect the forum rules and DO NOT CROSS POST! I deleted the other post since this one had a response.
2008-06-19, 21:08
I, I mean that as sub db doing in recorded matrial certified visible in xbmc
2008-06-19, 21:13
Xbmc has no suport for Dreambox rec sub.
In any case may be, I do not sub to work.
Strangely when Dreambox is so popular.
Works fine otherwise play the recorded matrial with xbmc from dreambox hardisk !
2008-06-19, 21:46
karra whats your mothertongue? please typ your message in that language...
cause i can't make head nor tails of your post..
you mean the subtitles? when you record..? those subs are @ teletext aren't they?
2008-06-20, 12:38
Swe.. :=)
När man har hårdisk i Dreambox eller om man spela in en kanal till mountad hårdisk.
Så lägger Drembox til text(sub)på filmer .
Läser man denna film sedan med en annan Dreambox genom nätverket så får man text på filmen.
Går man in med xbmc genom nätverket till Drembox hårdisk läser filmen funkar det utmärkt men det blir ingen text(sub)
Så xbmc kan ju inte ha stöd för text (sub) av inspelat matrial från d.b
Mycket synd man vill ju ha text när man kolla filmer från Drembox hårdisk med xbmc.
Så man skulle villja ha stöd i xbmc för att läsa dreambox (text/sub) konstigt att inget fixat det då nästan alla har en Dreambox idag.
Skulle det gå fixa stöd för det i xbmc skulle det vara super.
2008-06-20, 13:06
This would probably also allow subs in the streams using the tuxbox client. Have not seen any linux player that can display the subs in the .ts stream. Anyone has one that works?
Du vet om man kan köra tuxbox klienten och se live kanaler?
2008-06-20, 16:44
(You know, if you can run tuxbox client and see live channels?)
It is as simple press rec on Dreambox (Webinterface) then take it up with xbmc from hardisk only to wait 10 sec.
But as I said no sub: (
2008-06-20, 16:46
Crocodile
Going a little check on the fins of a media player display the subs in the. Ts
2008-06-20, 18:15
karra there is a patch in the pipe line which allows you to watch dreambox straight at xbmc.. without 'recording'...
'tuxbox' it is called
