2019-03-07, 22:29
kodi 18 just shuts down and must restart
Same file on kodi 17.6 plays just fine.
Not sure if I want to try 18.1 as had some issues with playback of music videos with that one..
Here is a media info of the file..
General
Complete name : C:\Temp\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 29 min 23 s
Overall bit rate mode : Variable
Overall bit rate : 4 871 kb/s
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@main
Format settings, BVOP : No
Format settings, Matrix : Default
Format settings, GOP : N=18
Bit rate mode : Variable
Bit rate : 4 518 kb/s
Maximum bit rate : 9 000 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.436
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 950 MiB (93%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Muxing mode : DVD-Video
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Delay relative to video : -39 ms
Stream size : 53.8 MiB (5%)
Service kind : Complete Main
General
Format : MPEG-PS
Video
Format : MPEG Video
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Audio
Format : AC-3
Bit rate : 256 kb/s
Bit depth : 16 bits
