I'm sure most of you have tried a few skins and I have been holding back updating Kodi to Leia due to AZ not yet being compatible. Then I tried Eminence... it's basically the same thing and already compatible. Try it.
I use the Leia modded version without any issues until AZ2 is ready.
Friend you know that the latest version of the original AZ is compatible with kodi 18.
You can even download AZ Plus and AZ MOD from Beatmasters
AZ Plus ?
ignore found it.
actually looking at "plus" , its krypton only isn't it ?
oh crap , having a bad day , found the update as well duh.
I responded with short answers. Recapitulating, existe AZ ORIGINAL On GitHub
There is AZ Plus on the last page of the topic
There is AZ mod from Beatmasterrs in the topic AZ MoD.
All running in the last Kodi 18.1
Oh ok... I have not tried downloading it anywhere else except through kodi's repository. I actually quite like the Eminence skin and think I'll use it for a while.
